turn signals
Old Mar 16, 2010 | 09:33 PM
tdawg_79's Avatar
Default turn signals
I have a 95 Accord EX. Having problems with the turn signals. Just bought the car. The right turn signal blinks non stop if the flasher relay is in. No matter if the key is on or not. The left turn signal still works properly, but the right signal still blinks at the same time. Need help.
Old Mar 16, 2010 | 11:44 PM
The three components that make up the turn signal/hazard system are the turn signal switch, hazard switch, and the relay. Don't forget about the wiring.
You can get a 94 shop manual from the spooner site I posted in the online manuals thread in the DIY section. It that has all of the tests for those components.
Just from how you described your problem, my guess is that the hazard switch has a short between terminal D and F. There is also the possibility that you have a dirty or loose ground at 402/404.
Old Mar 22, 2010 | 02:15 PM
tdawg_79's Avatar
Thanks for the help. I bought a new hazard switch. Put it in and the blinkers work just fine now. It is amazing how something that simple could make for such a problem. Thanks again.
Old Mar 22, 2010 | 03:48 PM
Exclamation
Good answer with a good fix...Good Post
dan_o_89_rs
Aug 22, 2011 05:51 PM
Codonah
Oct 14, 2007 08:58 PM
gliff159
Apr 27, 2007 03:40 PM
kennilope
Jan 26, 2007 03:14 PM
jrschmank
Jun 4, 2006 07:13 PM
