turning on car on winter but cant lock doors when leaving engine running ?
Old Dec 11, 2012 | 07:06 AM
renzovc16's Avatar
Angry turning on car on winter but cant lock doors when leaving engine running ?
whats up people i need help ASAP i got a 09 honda accord v4
im in new york en is winter and i dont have a remote starter
so my car is parked always accross my house so i wake up in the mornings and usually sit there untill the engine is warm then drive off, BUT THIS MORNING i was like, let me turn the car, let it get warm then go back to my house , and the engine was running but the car didnt let me lock the driver door ? it was cold so i went back to the house and start thinking why it does that, and also i was keeping en eye on my car so nobody would try to steal it lol what can i do ?:rolleyes :
Old Dec 11, 2012 | 09:18 AM
shipo's Avatar
First things first; it's a bad idea to warm up your car the way you are, it's hard on the engine and the oil. You're far better off simply starting the engine, clicking on your seatbelt, checking your mirrors, putting it in gear and gently driving off. By doing this you minimize the amout of time the engine is running while cold and dramatically reduce the oil contamination which results from extended idling, especially when the engine is cold.
Old Dec 11, 2012 | 11:32 AM
As noted in the owner's manual:
Lockout Prevention
If you forget and leave the key in the
ignition switch, lockout prevention
will not allow you to lock the driver’s
door. With any door open and the
key in the ignition switch, locking
with master door lock switch is
disabled. If the driver’s door is
closed, the lock tab on the driver’s
door is not disabled. Pulling the
driver’s lock tab rearward will lock
all doors. If you try to lock an open
driver’s door by pulling the lock tab
rearward, the driver’s door lock tab
pops out and unlocks the driver’s
door.
Some FAQ on Honda's remote starter (add-on accessory):
http://www.handa-accessories.com/remotestart.pdf
Old Dec 11, 2012 | 05:36 PM
renzovc16's Avatar
thanks a lot guys
daver1100
May 30, 2014 08:00 AM
Amtrak288
Aug 31, 2011 08:18 PM
spiker369
Jun 16, 2011 01:46 AM
TomC
Nov 8, 2010 05:42 PM
