Turning Steering wheel hard at first when it's cold?
Old Dec 11, 2013 | 09:20 AM
b8man's Avatar
Default Turning Steering wheel hard at first when it's cold?
Hi everyone! New to the forum. My 2004 Honda Accord is getting older and feel that I need to jump in this forum so that I can start becoming more knowledgeable to take care of my Accord as it ages.
Problem:
When it is cold during the winter, my 2004 Accord is hard to turn unless you let it warm up quite some time +10 minutes minimum. Then...no problems. I tend to not think that the steering fluid would get cold....? Sooo.... I'm at a loss.
Anyone else experience this or have an idea why that would happen?
Thanks for your insights!
Old Dec 12, 2013 | 10:22 AM
A common problem on many Honda/Acura products is an air leak into system on suction hose inlet fitting to power steering pump (sub-ambient so air gets pulled in). There is usually groaning/whining sound from pump during this time.
As fluid warms oring eventually seals and air is circulated out to reservoir and symptoms disappear.
Fix is to replace oring on inlet fitting. Remove single bolt holding fitting and oring is underneath that fitting. Replace w/ OEM oring from Honda parts.
You can confirm by observing fluid in reservoir when cold. If foamy, then leaking air into system is confirmed.
Old Sep 20, 2017 | 04:24 AM
Torneo's Avatar
hi Guyz happy to be here on this forum, my honda Torneo/accord has a hard steering wheel and it tends to steer on the right side unless you keep hold of the steering wheel tight will driving. please any advice. thanks.
Old Jan 1, 2018 | 08:33 AM
05EXAccord's Avatar
Do you have an oem part number for the o-ring or the line that’s typically associated with this issue? I’m pretty sure I’m dealing with this issue currently and according to the diagram I found, the only description that says suction on it is just a rubber tube from the PS pump to the reservoir with no actual fitting. Was it the fitting on the top of the pump itself?
Old Jan 2, 2018 | 09:25 AM
See attachment. I don't have info on part number. Suggest calling a Honda parts store.
hmr
Oct 20, 2013 10:30 AM
d0n
Aug 26, 2013 01:15 PM
1999EX
Mar 29, 2013 03:22 PM
mrscotty
Dec 11, 2007 08:00 PM
