Twist Tie Fell Inside Spark Plug Hole!
Old Sep 24, 2008 | 01:53 PM
92_accord_honda
Default Twist Tie Fell Inside Spark Plug Hole!
Yes, this is going to sound awful, but when I was changing my spark plugs, there was oil in the far right hole. So, in a dumb idea, I used a twist tie at the end of a metal rod to attach a rag, and the twist tie came off and fell into the spark plug hole, and I can't see it. Do I have to take off the cylinder head to remove it, or can I fire up the engine and it will burn it up? The only way I can think of to get it out without taking the cylinder head off would be to stick a tube inside and have it attached to a vacuum, or a magnet on a string, either of those ideas sound like they would work? How much space is inside underneath that one hole?
Old Sep 24, 2008 | 02:09 PM
Default RE: Twist Tie Fell Inside Spark Plug Hole!
doesnt seemlike a good idea to fire it up, as twist ties have a metal piece inside that could/will cause damage
Old Sep 24, 2008 | 02:18 PM
finch13's Avatar
raise whichever cylinder to TOP DEAD CENTER and stick they ol' vaccum in.
Old Sep 24, 2008 | 02:26 PM
damn nice new sig pic there finch
Old Sep 24, 2008 | 02:31 PM
Fenix's Avatar
autozone/barn sells thin magnetic probes, perhaps small enough to get in the hole. You'd be fishing in the dark for the twist tie but it may save some time. Magnet on a string is a bad idea cause you could end up loosing the magnet in the hole too.
Old Sep 24, 2008 | 02:38 PM
finch13's Avatar
wait is it a twist tie (bread bags) or a zip tie? lol... yeah if its a twistie use a magnet.
ORIGINAL: live2rice
Thank man... I finally got around to making one... it's only temporary, I don't like the glare off the lights, but it hides the fact that my car isn't modded and has steelies on it...
Old Sep 24, 2008 | 02:45 PM
i think the glare makes it jdm yo, heres what you do you make the glare red so it looks like this
Old Sep 24, 2008 | 02:50 PM
finch13's Avatar
HAHHHAHAHAHAHA
Fawk yeah! A rising sun at dusk would be mad JDM yo.
Old Sep 24, 2008 | 02:52 PM
falkore24's Avatar
I'd try the magnet .... it's not going to be easy since it's going to stick to everything in there, but worth a try.
Old Sep 24, 2008 | 04:31 PM
jerrym's Avatar
Almost A Senior Member
Empty out a small shop vac. Use a smaller diameter piece of hose that will fit in the plug hole and suck it out. With a clear hose you might even see it go by!
