UK garages for Accord (55 plate) diesel turbo replacement?
Old May 17, 2010 | 02:22 AM
jkerai's Avatar
Default UK garages for Accord (55 plate) diesel turbo replacement?
Hi Guys i have Honda Accord 55 plate, done around 85000 miles, i noticed the car is not picking up any speed at all and theres white smoke from exhaust, theres no warning lights on the dash board,any ideas?? Many Thanks Jay
Old May 17, 2010 | 06:42 AM
White smoke sounds like a headgasket problem. Check your coolant - in the radiator not just in the overflow bottle.
Old May 17, 2010 | 06:51 PM
George.Galo's Avatar
Check your oil too, if it's milky or frothy, it's getting coolant in it, another sure sign of a bad head gasket.
Old May 18, 2010 | 07:36 AM
jkerai's Avatar
Thanks for the replies! Ive taken the car to few Garages, they all seem to say 90% its my turbo, im in the process buying new turbo am i doing the right thing? is there any cheap turbos knocking around ive got a price for £250 done around 50,000 miles onit:?
Old May 18, 2010 | 10:13 AM
Turbo? You never said anything about turbo. What do you really have? Is this a diesel?
Old May 18, 2010 | 01:28 PM
jkerai's Avatar
Sorry i have a diesel car, its also leaking oil from the exhaust now
Honda Accord 2.2cdti
Old May 18, 2010 | 03:42 PM
OK, I should have realized when you said "55-plate" because that's a British thing, right?
Still, the suggestions about headgasket & other things to check should still apply. When you said turbo, the first thing that crossed my mind is you added a turbo to an engine that didn't have one from the factory.
Diesels have higher combustion pressures, so they put more stress on the headgasket. Although it should be designed for that, you need to check out all those things because it sounds like it could be a blown headgasket.
However, the turbo throws another source into the mix. Blown seals in the spool can put oil and/or coolant into the exhaust line.
You could try a compression test and/or a leakdown test to rule out headgasket, leaving the turbo spool as the likely suspect.
Old May 18, 2010 | 04:00 PM
jkerai's Avatar
yep thats the one 55 plate, sorry no i havent had any modification on the car etc, the car is as it came when i bought it from auction, i took it to another garage today and they have said its the turbo, im guno have to cough out £500-600, you know any garage that are doing 2nd hand turbo for Honda Accord?
Old May 18, 2010 | 09:11 PM
I'm gonna change the title of the thread so maybe it'll attract attention from UK people.
Honda never sold the diesel engines AT ALL in the USA. Besides you probably don't want to ship the car over here for repair anyway. I've been to England, but I had a hire car so I never had to look for a repair shop.
It's probably good that it's the turbo; I think that would be cheaper than a headgasket anyway.
Old May 19, 2010 | 12:24 AM
jkerai's Avatar
Thanks Jim
shabba
Sep 9, 2009 09:42 PM
aimee
Feb 7, 2009 12:00 AM
scoobysteve
Jan 13, 2009 04:13 PM
jipmpizzle
Dec 18, 2007 10:38 PM
Jul 31, 2005 04:14 PM
