Ulev ?
Old Oct 15, 2012 | 12:42 AM
Marc9720's Avatar
Post Ulev ?
ok so im having trouble trying to find the right o2sensor
the original engine in my 99 accord was a f23a4 with ULEV the exhaust manifold is different then a f23a1 how ever I did a engine swap to a f23a jdm
I was wondering what sensor should I be using the one for ULEV or the stock one ( I did not swap ecu)
Old Oct 15, 2012 | 05:34 AM
read posting rules. No posting in DIY forum.
You need to describe what sensor forward Oxygen (fuel/air) sensor, or other?
I recollect the forward oxygen sensor is a fuel/air mix sensor (more expensive than O2 senso).
Old Oct 15, 2012 | 08:05 AM
Marc9720's Avatar
upstream one in the front
thanks for the help your my hero
Old Oct 15, 2012 | 08:01 PM
When the swap was done, which O2 was put into the car? When the swap was done there were NO codes afterwards?
Old Oct 15, 2012 | 10:53 PM
Marc9720's Avatar
I had the one from the f23a4 ulev model
it was good up in till 2 days ago I did the swap a few months back
Old Oct 16, 2012 | 10:46 AM
Dr. Drivability's Avatar
you should use whatever 02 sensor the car was originally equipped with, the computer has those parameters programmed in for that specific sensor.
Old Oct 16, 2012 | 11:13 AM
Yeah, the car was originally equipped with the F23A4 (ULEV) engine and he kept that ECU. That's the O2 sensor he used, so the sensor is compatible and didn't throw a CEL immediately.
But maybe subtle differences in the JDM F23A are causing it? The exhaust manifold is the obvious difference, but I don't know if there's anything else different (cam profiles, etc?)
Old Oct 16, 2012 | 12:05 PM
sensor could have just gone bad too...nothing more nothing less
Old Oct 16, 2012 | 07:07 PM
Marc9720's Avatar
ya i replaced it with the correct one ULEV MODEL and its oem denso and did not like that at all it ran even worse
Accord12404
Sep 18, 2019 09:18 AM
jhillblessed
May 10, 2010 09:55 AM
Adam182R
Jul 29, 2007 11:47 AM
chesswiz
Apr 6, 2007 03:08 PM
01Accord
Feb 6, 2007 11:37 AM
