Uneven brake wear on 2000 Accord
Old Mar 25, 2008 | 12:26 PM
Planefreak's Avatar
Default Uneven brake wear on 2000 Accord
I just finished doing a brake job on my dad's Accord. It has around 120,000 miles and it just got a lot of firsts. New plugs, rotor, cap, cabin air filter, and brakes. The brakes were in definite need of work. On both of the front brakes the inner pads had less than 1/16th of an inch of pad left while the outer pads had about 1/4 to 3/8 inch of pad left. They were exactly the same on both sides. I know uneven wear is bad but the car doesn't brake funny and the pads are worn the same which points to Honda, but shoud I be worried or even care?
Thanks.
Old Mar 25, 2008 | 12:33 PM
finch13's Avatar
Default RE: Uneven brake wear on 2000 Accord
The slide pins probably just dried out in the middle of the life of the pads. Uneven wear is a common symptom of that.
Old Mar 25, 2008 | 12:34 PM
Planefreak's Avatar
Should they be replaced?
Old Mar 25, 2008 | 01:25 PM
smaglik's Avatar
just make sure you relubricate them.
Old Mar 25, 2008 | 01:41 PM
finch13's Avatar
Yeah, make sure you wipe all the dry grease off and well, what I do is just dip them in my big can of disc brake grease and away they go.
ryanw2427
Jul 5, 2015 07:54 PM
Deep Diver
May 7, 2013 09:36 PM
Cash
Nov 15, 2011 02:40 PM
dderolph
Oct 7, 2011 11:36 AM
russell
Sep 4, 2007 09:08 AM
