Unknown plug disconnected???
Old Mar 30, 2012 | 04:15 PM
Stew Pot's Avatar
Default Unknown plug disconnected???
Hi.
I just bought an 2000 Accord - 1850cc.
I just started to look for the OBD connector, but instead found this plug, (see attachment), disconnected, just under the glove box, above the passengers feet.
Does anyone know what this plug is for?
Thanks
Old Mar 30, 2012 | 05:18 PM
It appears to fit the "holder" immediately above the plug.
Old Mar 30, 2012 | 05:38 PM
crispin's Avatar
OP - based on you having the 1.8L you do not have a US model.
There are not a lot of members here from outside the US.
I am not sure how different your wiring is vs ours.
Now I will say that I believe your ODB II connector is located behind your ashtray.
If everything is working correctly on your car then I would not connect it, just my opinion.
Old Mar 31, 2012 | 04:01 AM
Stew Pot's Avatar
It appears to fit the "holder" immediately above the plug. good luck
Hi.
I did see the mating socket, I was just afraid to plug it in, in case someone had removed it for a good reason.
Didn't want to rock the boat.
I've ordered the Haynes manual, so once it arrives I should be able to figure out what it's for.
The car is hesitating between 1000 and 2000 rpm during acceleration.
It idles fine.
It doesn't hesitate when cold, so I want to first check the coolant temerature sensor before starting into the EGR passage clearout.
I've searched high and low for the OBD socket and can't find it. Some other forum threads suggests some don't have the normal OBD socket.
(There is no MIL lamp on anyway. I was just curious to see if there is any data logged in the OBD freeze frame).
Hopefully the manual will shed some light on it, but I imagine it will be specific to the usa models.
Thanks
Old Mar 31, 2012 | 07:14 AM
I wouldn't plug it in unless the holder doesn't have any wires leading to it or something is not working correctly on the car. IE, it's nothing but a holder. There are some like this to protect diagnostic plugs. I haven't seen one w/ that many wires, but may be there.
Old Mar 31, 2012 | 09:44 AM
Stew Pot's Avatar
oops.
Sorry, I've been a plonker.
Just had a closer look and now realise the holder is just a holder.
I thought it had wires coming from it but I was wrong.
Maybe this is the diagnostic socket then?
Hopefully the manual has some more info.
Thanks
Old Apr 4, 2012 | 05:01 PM
Stew Pot's Avatar
Default Problem solved
Turns out the 5 pin plug is the OBD connector.
I suspected the EGR valve was dodgey, and true enough once I got the relevant code reader and connected it, the EGR voltage was 0v during a test drive. (No engine management light was illuminated on the dash by the way and no fault codes were present - strange).
I took the code reader out through the window to the engine bay and wiggled the connector. Ahhhhh, I got a voltage.
Wiggled it again - no voltage, and so on.
Once I had wiggled it in such a way as to maintain a constant good connection, I took it for a drive with the live data showing.
The car has driven fine since. (Before it was hesitating during acceleration). It has continually shown a voltage trace consistent with my test drive.
For example when OFCO is active, the EGR voltage trace flatlines as would be expected.
Then when I apply the gas again, the EGR voltage becomes active again.
I need a closer inspection of the plug and loom to ensure a more long term solution.
I never could have found that fault without the code reader.
cmcconkey
Oct 22, 2011 11:53 AM
hack
Jul 12, 2011 06:12 PM
ryanw2427
Aug 30, 2010 08:17 AM
elderfoster
May 25, 2009 02:44 AM
Ranmaster
Apr 12, 2008 08:24 AM
