Sponsored by:
Sponsored by:
Upper control arms 1999
Old 07-06-2009, 12:03 AM
ml2008
Unhappy Upper control arms 1999
sent my car for changing oil, the machanic told me I need to replace both front upper control arms for my 1999 Accord LX. He said this is a "safety issue", and he showed me he could move the tire a bit up and down. The cost is $510 (part &labor) + $90 (for alignment). My questions are,
1) How do I know/measure it is time to replace the upper control arms?
2) Is the cost too high?
Thanks,
Ming
Old 07-06-2009, 02:34 AM
I know that you would be in deep trouble if the upper ball joint separates when you are driving. The tire would pretty much fall down.
Since the upper ball joint is loose, you should consider replacing. I would definitely get a second opinion from another shop.
The Honda parts are probably around $150 each, so the quote may be accurate.
Old 07-06-2009, 03:12 AM
finch13's Avatar
Honda will only sell you the upper control will the ball joint as one unit, around $125 each side online. I bought and replaced the ball joint with a Moog one ($50 most parts stores) which has a grease fitting and is a lot beefier than OEM.
The strut needs to come out and the ball joint separated from the knuckle, but all in all it was 2 bolts and 6 nuts that needed to be removed to complete the entire job. All in all, it's only a 1 hour job at the most for a mechanic, so they shouldn't charge you more than $130 before tax.
Old 07-06-2009, 08:17 AM
And then you still should get an alignment when it's done.
Old 07-06-2009, 09:33 AM
ml2008
Thanks for all your replies. My 1999 Accord ~135,000 km, it seems driving fine, no noise from the suspension on bumps. It seemed to me the machanic picked up this 'issue' randomly, so I had the question is: how do you know the arms are loosen and could cause safety issue? any other signs I could pick up while driving?
Ming
twilliamsen
08-31-2010 09:43 AM
kennilope
04-28-2010 06:46 AM
ml2008
07-07-2009 04:11 PM
Jmoney
04-28-2009 09:06 PM
deerok
01-02-2009 07:32 AM
Quick Reply: Upper control arms 1999
