USB charging port(S) 97 Accord EX 96 Civic DX
I would like to add one or two USB charging port to both my 1997 Accord and 1996 Civic DX hatchback. Both have rectangular switch knockouts that appear to be an excellent location for the ports. Has anyone found a source for a unit that will fit into the switch opening? I plan to either run directly to the inside fuse box or off the same circuit as the cigarette lighter.
Thank you in advance for your assistance.
Sincerely,
Brķan S. Du Bois
Evansville, IN
Sincerely,
Brķan S. Du Bois
Evansville, IN
Sincerely,
Brķan S. Du Bois
Evansville, IN
There are single or dual usb power socket with voltage regulators built-in already available; that you can hardwire into a 12 volt source. You would either drill/cut a hole anywhere or use the existing cigarette lighter location (remove cigarette light socket first); and insert the usb socket, then wire it up.
One wire goes to a ground source, the other wire goes to a power source (which you can use a Littelfuse Add-a-Circuit to a fuse box slot).
Ebay, etc. has them.
Mikebike125
Nov 15, 2012 08:43 PM
ctbear
Nov 30, 2011 10:28 PM
