Valve Adjustment 95' V6
Old May 15, 2008 | 02:58 PM
forest337
Default Valve Adjustment 95' V6
I've found a lot of valuable information about valve adjustment on the forum already (mostly I4, though), and I have a detailed .pdf showing how to perfrom this on a 2003 V6. Is there anything specific I need to know about performing this on a 95?
Many Thanks!
Old May 15, 2008 | 03:14 PM
hondaed's Avatar
Default RE: Valve Adjustment 95' V6
Service manualsays to check valve adjustment every 105,000 miles (more often onlyif noisey).
You only check valve clearance with enginecold (off for at least 12 hours is best)
Check each set of valves (per cylinder) with piston at TDC compression.
Intake 0.20 - 0.24mm (0.008-0.009 in.)
Exhaust 0.28 - 0.32mm (0.011-0.013 in.)
Ed Brian
Accurate Automotive, Inc.
www.accuratecars.com
Old Dec 11, 2015 | 10:25 PM
Kayela32's Avatar
Default Adjusting valves
What tool are used to adjust the valves, and is there a you tube video to go by.
Old Dec 11, 2015 | 10:30 PM
Kayela32's Avatar
If its a v6 and you do, will you please pass it on
eleiko
Jun 15, 2011 10:46 PM
deserthonda
Dec 31, 2007 09:16 AM
deserthonda
May 12, 2006 12:13 AM
mpanelli
Apr 18, 2006 08:32 PM
sfox555
Feb 2, 2006 07:42 PM
