Very poor mileage issues 2005 Accord
Old Oct 15, 2008 | 07:11 AM
08coupex's Avatar
Default RE: Very poor mileage issues 2005 Accord
Ethanal is a definite problem for everyone. Try cleaning out your throttle body and swapping out your plugs. Check your wires to make sure they arent grounding out or at the very least arcing. When your oil change is up switch to full synthetic if you havent already. Check your air filter to make sure its clean. Also if you use the same gas station, switch to another one and see if that makes a difference.
Old Jan 16, 2011 | 08:36 PM
skibikesoccer's Avatar
Default Very poor mileage 2005 accord
I am with slow eddy. I have an 05 4cyl auto with 32000 miles which gets 19 city and 23 hwy and these are the best I have been able to achieve in teh past 6 months with the car. I have noticed the trans torque converter lockup rarely activating or staying active with a slight throttle change. This is the first car owned in 25 years that did not provide something close to fuel economy ratings. With all the transmission failures reported in internet, I would consider a normally excessive slipping transmission a primary cause of poor fuel economy and transmission failure. In my case the driving style is not a cause, but must be a difficult to define or diagnose flaw in the automobile [even if the flaw is normal]. I looks forward to continuing posts.
fahd_628
Aug 21, 2015 09:51 AM
gdimattia
Nov 30, 2014 09:02 PM
tiredredcoupe
Nov 13, 2009 06:17 PM
porcorosso
Feb 13, 2008 07:34 PM
thecaveboy
Feb 1, 2007 04:17 PM
