Viberation at Idle
Old Feb 2, 2006 | 04:20 PM
ernie22golf's Avatar
Default Viberation at Idle
My 03 Accord 4cyl is as smooth as silk...except... when I come to an idle. This is worse when the A/C is running. The car runs great other than this. I haven't had the car long and will soon be doing a mileage test to see that gas mileage is reasonable. Just didn't know it this viberation is inherent with the 4 cyl so not to worry or might signal something to be corrected.
Thanks
Old Feb 2, 2006 | 04:28 PM
marbro's Avatar
Default RE: Viberation at Idle
What rpms is your car idling at?
Old Feb 2, 2006 | 05:53 PM
I believe it is approx 700rpm when warm & say 1000 when cold or more.
Thanks
Old Feb 2, 2006 | 07:39 PM
deserthonda's Avatar
if less than 36,000 miles take it to a Honda dealer you are still under warranty,, if out of warranty, chk the motor mounts, try raising the idle up a bit to 750-800 rpm..
Car been in any accidents at all ??
Old Feb 3, 2006 | 04:50 PM
No accidents per carfax. How would I check the Motor Mounts.
Thanks
Old Feb 3, 2006 | 09:42 PM
RTexasF's Avatar
Super Member
There is a Honda TSB out for your model's rough idle. I searched but can't seem to locate it. Contact a Honda dealer and let them find it.
Old Feb 3, 2006 | 11:27 PM
2003 Honda Accord
Bulletin #: 04024
Sequence #: 10008712
Date: 05/04/2004
Component Name: 061000 engine and engine cooling:engine
Make: Honda
Model: Accord
Year: 2003
Summary: Engine vibrates while idling in gear. *mj
like Rtex says call dealer ,and inquire if they can fix your car free of charge
Kpick
May 5, 2015 08:51 PM
HatchJunki
Mar 9, 2013 08:23 AM
90pioneer
Apr 9, 2012 09:06 PM
RWilliams
Jul 24, 2011 09:16 PM
fperezal
Jun 14, 2006 05:03 AM
