Vibration 2019 Accord
Old Aug 3, 2021 | 12:42 AM
engmalek's Avatar
Default Vibration 2019 Accord
Hi everyone ,
I am a new owner of 2019 Honda accord.
my 18K miles Accord 2019 is vibrating after the RPM goes above 1000 and the strange thing if I open the front windows even just a little the vibration will go immidaltly.
I changed the front bumper recently due to accident.
Is it related to the bumper replacement of second hand.
I also read about the noise cancelation system deactivating? Do you think it has any relation?
thank you
Old Aug 3, 2021 | 11:23 AM
IF it started right after the bumper replacement, then that makes sense. Does everything line up properly?
Does it happen if you rev the engine above 1000 without moving the car?
Look underneath the front, for any plastic panels that are loose and flapping in the wind as you drive.
(I don't know much about the noise-cancellation system.)
I'm moving this to General Tech where more people will probably see it & help.
Old Aug 3, 2021 | 09:16 PM
engmalek's Avatar
Thank you for your reply .
I think with my mechanic could find the cause .
yesatdy I was driving the car and realized that if I open ant FRT car windows the sound will go immidaitly.
I read about it and it seems the sound is coming from the speakers that caused by the Noise cancelation system.
He will check the speakers around the car and if all seems okay then we will deactivated the Noise cancelation system.
Old Oct 22, 2021 | 08:46 AM
ALOSSAFH's Avatar
Default I have the same problem
Hi, i have the same problem with honda accord 2019 the same as you described when i open the windows the sound goes , its a very annoying strong vibration did you find any explanation for it?
if you did then what is the solution?
thank you very much
Old Oct 23, 2021 | 06:49 AM
engmalek's Avatar
Yes it was ANS ..I just unpluged it and the noise is away.
either you installed implifier or new speakers..that caused this noise .
Old Dec 2, 2021 | 09:12 AM
ALOSSAFH's Avatar
Would you please tell me how you unplugged it?, the issue happened to me more then one time this month so what is better to unplug it? No problems will happen to the car or fix it and change the whole speaker / mic system?
thank you.
Old Dec 2, 2021 | 11:59 AM
There are various YouTube videos on how to disconnect the active noise cancellation.
Google "2019 Honda accord active noise cancellation"
Old Dec 2, 2021 | 12:31 PM
ALOSSAFH's Avatar
Thanks man, but one last question is it better to just go to Honda and fix it? Is it included in the warranty? Or unplugging it is easier and don't effect the car?
SE2012hags
Apr 7, 2017 04:03 AM
zoid_99
Jun 28, 2012 10:41 AM
arcticf1re
Apr 9, 2010 10:14 PM
superballz00
Oct 6, 2007 08:36 PM
janicesaccord
Mar 4, 2006 08:18 PM
