Vibration over 30mph.
Old Nov 4, 2008 | 04:56 PM
Am4wag's Avatar
Default Vibration over 30mph.
Just replaced t/b,b/b,w/p,both cv shafts,and sway bar end links about a month ago.Now my sister tells me the car has a vibration over 30 mph. on the left side.Yeah,that's where I just did all that work,and as far as I can remember,I did it properly with the (very much appreciated) help in my post.
https://www.hondaaccordforum.com/Bal..._141389/tm.htm
I onlydrove the car a couple of blocks when I had finished it,so I'm not physically aware of the vibration,and it runs like a champ.Any input would be appreciated......
Old Nov 4, 2008 | 05:02 PM
finch13's Avatar
Default RE: Vibration over 30mph.
Well, you can rev the engine in neutral to see if it's the balancer belt. When's the last time she got an alignment?
The T/B was done a month ago, if you did something wrong there, she would've noticed the first time she drove it, not a month later.
Old Nov 4, 2008 | 05:26 PM
Am4wag's Avatar
Well,now she tells me (I grilled her)that it vibrates when slowing down from above 30 (like on the hiway/50 or so) down to about 30 (when vib. occurs).....only when useing the brakes...(whew,I thought it was something I did/did'nt do) .But anyway,I guess I'll be looking at the brake(s) now..warped rotor maybe?
Old Nov 4, 2008 | 05:35 PM
finch13's Avatar
Warped fo sho. Tell her not to brake hard... I'd still drive the car myself before i did more work on it.
Old Nov 4, 2008 | 06:38 PM
Am4wag's Avatar
What is the difference between Nissan brakes and Akebono brakes?.....(wow,gone from balancer to brakes in 4 posts).
Old Nov 5, 2008 | 09:09 AM
falkore24's Avatar
Nothing. Get Brembo's.
Old Nov 5, 2008 | 01:30 PM
finch13's Avatar
Nissin/Akebono make the calipers, Aaron. But, yes Brembo blank rotors are better than OEM and stand up to warping much better.
Old Nov 5, 2008 | 02:22 PM
Am4wag's Avatar
Old Nov 5, 2008 | 02:37 PM
finch13's Avatar
Links don't work. It would be cheaper to shop around online for parts....
Old Nov 5, 2008 | 02:44 PM
falkore24's Avatar
Links don't go to a product, only a blank search
