Vibration when Braking
Old Nov 27, 2007 | 12:20 PM
deserthonda's Avatar
Default RE: Vibration when Braking
ORIGINAL: shergill
I called the dealer and they said they will 'machine the rotors' for about $280. He said brakes are not covered under warannty
that's a bunch of BS. wear on the brakes are not covered . but warped rotors shoulf definatelly be coverd .. ask to talk to the service manager and or Honda district manager
they should do it under warranty ,, do not take no for an answer
Old Nov 27, 2007 | 02:48 PM
klrspz's Avatar
If you're able to take the rotors off and take them somewhere, you could get it done a lot cheaper than that.
On my 03 Coupe, it took like 10 minutes to rip off both front rotors, and it took the techs about an hour (in which time I installed the Koni & Eibach setup), then reput the rotors on in another 10 minutes.. it's really a no-brainer of a task and could save you some dough.
Otherwise, the 2nd offer you said from Sears isn't too shabby.
I'd skip the diagnostic cost though, go straight to machining if the breaks look good.
Old Nov 27, 2007 | 02:55 PM
falkore24's Avatar
Spaz .... if the rotor set screw is siezed in place, it could be a real PITA to get them off ..... I had that problem .... coincidentally when my grandfather had my impact screwdriver!
Old Nov 27, 2007 | 03:03 PM
just for kicks ,i just called the Honda dealer in town and talked to the service advicer .. he told me
Absolutelly, no if ,and or buts, positivelly ROTORS are coverd under warranty 3 yrs -36k miles
Go talk to the service manager and raise some hell ....Honda Warranty should cover the cost of resurfacing or replacing the rotors ...
Old Nov 27, 2007 | 03:22 PM
00AccordLX5spd's Avatar
Registered User
That's why I suggested warranty. Rotors are not at all the same as pads. Rotors should surely last longer than 20k.
Old Nov 27, 2007 | 03:46 PM
falkore24's Avatar
x2 ..... also, 280 is rediculous!!! You can get brand new Brembo blanks for $40 a piece
Old Nov 27, 2007 | 05:53 PM
  #17
shergill's Avatar
I will call the service advisor again. Thanks
Old Nov 27, 2007 | 10:27 PM
  #18
shergill's Avatar
Called Service Advisor again. He said 'rotors are only covered until 12k or 12 months'.
Old Nov 27, 2007 | 11:13 PM
  #19
nafango2's Avatar
do what falkore said. get some brembo blanks for $40 apiece. I hear OEM rotors arnt that good, and you dont hear a lot of problems with brembo blanks.
Old Nov 27, 2007 | 11:52 PM
  #20
http://www.spoke.com/public/pages/A/company/000/000/876
there are some phone #s there...ask for customer service .
call and complain .. like i said,, it should be under warranty 3 yrs 36k miles..
the service manager you are talking to is trying to rip you off..
