vss or tps?
hello all, i have a 91 accord lx AT and my speedo recently quit working. my tach works fine but the speedo, odometer, and tripmeter all just stopped and the s light is flashing. ive done some research and i think its the vss but i wanted to ask you guys and make sure its not the tps or something else i dont know about. thanks for any help i appreciate it.
kevin
kevin
There is a blue two pin connector that is behind the driver's side kick panel that you short with a piece of wire or a thin paperclip to get the transmission code(s) and engine code(s).
For VSS see: techauto.awardspace.com/vss.html
Here are the instructions for getting the code. The S light will blink the transmission code on your car:
techauto.awardspace.com/dtc.html
Just copy and past the link into your web browser, because we aren't supposed to post direct links.
ok i jumped the connector and i got a code 7 for the check engine light which is the throttle position sensor and a code 4 for the s light which is the speed sensor so i guess its both! thanks for the quick reply i appreciate it.
