vtec solenoid gasket
Old Nov 10, 2008 | 11:16 PM
pepaccordcd5
Default vtec solenoid gasket
hi im trying 2 find out how to instal on the vtec solenoid gasket
Old Nov 10, 2008 | 11:26 PM
Default RE: vtec solenoid gasket
take vtec solenoid off and install gasket?
Old Nov 10, 2008 | 11:27 PM
You should put your year and model in your signature to help us give you accurate info.
Old Nov 10, 2008 | 11:33 PM
pepaccordcd5
i should put my car info. but how hard is it 2 instal the gasket
[hr]
95 accord ex At
Old Nov 10, 2008 | 11:35 PM
take 3 bolts off, take old gasket off, put new gasket on, re install 3 bolts
Old Nov 10, 2008 | 11:37 PM
pepaccordcd5
Default RE: need help how to instal vtec solenoid gasket
its leaking alot help
[hr]
95 accord ex at
Old Nov 10, 2008 | 11:40 PM
pepaccordcd5
do i need 2 torque the bolts
Old Nov 10, 2008 | 11:41 PM
There are three bolts that hold the vtec to the cylinder head. Remove those and replace the gasket.
The problem is that at least one of the bolts is almost impossible to get at. Drain the coolant and remove the entire thermostat housing to access the lower bolt towards the middle of the car. You may want to take off the air intake tube to get more room in there.
Then the job is pretty simple once you remove that housing. You unbolt the engine side of the housing and twist/pull it off of the hard line that is fed by the water pump.
Old Nov 10, 2008 | 11:42 PM
dont over torque them i will try to get the torque specs, but i'm sure its not much.
Old Nov 10, 2008 | 11:48 PM
specs call for 8.7 lbf which is nothing
