Vtec Solenoide
Old Feb 12, 2011 | 02:12 PM
Diamond Accord 99's Avatar
Default Vtec Solenoide
Hi everyone! nice page! I'm trying to change the VTEC Solenoide gasket in a Accord 99 but the bolts are backward and inaccessible. Any recommendations?
Old Feb 12, 2011 | 02:33 PM
Moved your post to make a new thread.
You should take off the snorkel to the throttle body and probably should remove the entire thermostat housing to access that back bolt. That means you should change your coolant at the same time.
Two of the vtec solenoid bolts should be accessible. Do NOT use a boxed end wrench to loosen the bolt. Only use a ratchet and socket.
I am not sure what you mean by backwards?
trukid21
May 4, 2012 02:44 PM
PTVDesign
Oct 28, 2008 09:20 PM
FarRockAccord
18
Feb 1, 2008 06:36 PM
94coupeaccord
Feb 7, 2007 05:01 AM
