Water pump/timing belt replacement
Have a 2006 Accord V6 needs a timing belt and water pump replacement. Not sure if DIY capable or should bid the job out. What's the reasonable cost for this repair. Someone quoted around $800. Is that reasonable?
I've seen it typically quoted between $800 and $1,700; depends upon the shop and which kit they use. I opted for a shop which used the OEM Aisin Timing Belt/Water Pump kit and paid about $900.
hardlymoving
Sep 17, 2010 04:38 PM
pimpp1184
Nov 5, 2009 09:55 AM
mark95
May 18, 2009 11:47 AM
