Weak horn
Old Aug 12, 2015 | 11:19 AM
Biffy44's Avatar
Default Weak horn
I can't believe how wimpy the horn is on my new 2015!!!! I really don't want to go the air horn route, nor do I want to void my warranty! If I have to rewire or add wires, I would rather not. I was researching Hella and it seems they are about 8 - 10 decibels louder than OE but rewiring or adding sounds for sure. I'm also not sure about their sound? I want something that sounds like a typical US made car or truck (if you know what I mean), not something tingy or winey. Does anyone have any suggestions/advice?
Thanks!
Old Aug 12, 2015 | 11:53 AM
berrnard's Avatar
one of the best and easiest upgrades i did for mine.
Sports Horn Kit (pair) - DL163 - College Hills Honda
Old Aug 12, 2015 | 02:03 PM
Biffy44's Avatar
Thanks berrnard. LIKE YOUR AVATAR!
So I see they are plug and play. Was it really that easy, are you impressed with the sound and is it completely different, and have you had any electrical gremlins associated with this change or maybe any other issues?
Old Aug 13, 2015 | 06:16 AM
berrnard's Avatar
nope, super easy. just pnp, about a 10min swap. and i think they look cool cause you can see the thro the grill also.
Old Aug 13, 2015 | 07:54 AM
Biffy44's Avatar
I will give them a try. Thanks again!
Old Aug 14, 2015 | 12:07 AM
keep_hope_alive's Avatar
yes! i too want to add this to the list of mods.
Old Aug 14, 2015 | 05:22 PM
Prospector's Avatar
I did this same horn upgrade, purchased from College Hills Honda, reasonably priced, shipped fast... easy plug & play installation... sounds so much better than factory. I recommend it
Old Aug 15, 2015 | 12:34 PM
Biffy44's Avatar
I agree fast shipping!!!! They got them to me in 2 days. AWESOME!!! I just installed them and what a difference over the stock "beep" and that is being gracious
Anyway, I watched the video on College Hills site for installation just to make sure I wouldn't miss anything. I read the very brief installation instructions and followed them almost to the exact word. I put some dielectric grease in the connector since it was open. Below is what I did do because I couldn't see where they were mounted nor the reason for them:
I removed the "cover" that was part of a bracket that resided over the exit hole of the horn. Did I do wrong here and with the dielectric grease addition?
The installation was a breeze! Thanks to all for their suggestion of this item and I look to your feedback to my modifications to my installation.
Old Aug 15, 2015 | 03:48 PM
Prospector's Avatar
"Did I do wrong here and with the dielectric grease addition?"
I wouldn't think that should be a problem, may even benefit as a moisture barrier. As long as the horns are working to your satisfaction... you're good as gold
Enjoy
Old Aug 15, 2015 | 04:54 PM
berrnard's Avatar
grease is not needed at all, but whatever floats your boat. worst case, the brackets need a little sanding/scraping for a good ground contact.
