What are the best replacement Wiper Blades?
Old Aug 30, 2010 | 12:09 PM
MikeT's Avatar
Default What are the best replacement Wiper Blades?
I am getting tired of wiper blades only lasting a little over a month on my car. What are the best blades you have used? Initially most all of them work well but a couple of weeks into it they streak then they just start to self destruct and leave worn rubber on the glass. Is it me or do all the replacement blades stink? Have you had any luck with ones that last a long time?
Old Aug 30, 2010 | 07:43 PM
My opinion/personal experience. I use Trico blades, found at many retailers. I also clean the glass and use rain-x. I also try to wipe the rubber down with rubbing alcohol whenever I wash the car(s). Replace mine twice a year, just before spring and just before fall....I guess I'm about due.
Of course it does depend on climate. Temps and the amount of usage will make difference.
Old Aug 30, 2010 | 10:36 PM
EXV6NIGHTHAWK's Avatar
I just buy refills for the oem wiper blades, less than $10 and the wipers work like brand new again. Many aftermarket blades don't work well on the Accord's windshield.
Old Aug 30, 2010 | 10:40 PM
deserthonda's Avatar
Mike....there is something wrong with your wiper system,, blades should last a lot longer than 1 month and then some,,,,,,,,,chk wiper arms make sure that they are not bent and blades do not sit evenly on the glass ,,Any weird debris on the glass when you use the wipers thus tears the rubber up ??if you try to clean just fluid off windshield the inserts should last quite a while ..
PaperClip
Aug 29, 2011 05:42 PM
uAccord
Aug 26, 2008 08:57 PM
baileyismyhero
Feb 13, 2008 10:57 AM
ArcticHonda
Nov 10, 2006 12:53 PM
ACCBLACKEXL
Sep 30, 2006 09:06 PM
