what could be causing these problems?
Old Mar 23, 2012 | 09:34 AM
kyle102565's Avatar
if able, clean idle air control or replace.check for codes.
im thinking throttle position sensor
Old Mar 23, 2012 | 11:38 AM
ZeroMaverick's Avatar
The check engine light isn't on. Would codes still show any troubles even if the light is off?
Old Mar 23, 2012 | 04:57 PM
Okay I drained the old fluid. It came out a blood red color.
How many quarts of transmission fluid do I need to put? I put in 1 and a half, it was going to be two, but I spilled the first half trying to pour it without a funnel. After checking the transmission dip stick, I'm worried. The fluid isn't even showing on the stick...maybe I didn't put enough fluid?
Old Mar 23, 2012 | 05:21 PM
You drain about three quarts, so add two full quarts, then check the dipstick and keep adding until you add enough fluid to get it to the full mark.
Old Mar 24, 2012 | 04:56 PM
Okay I drained and replaced the fluid. It didn't help:/
Old Mar 24, 2012 | 05:26 PM
crispin's Avatar
It rarely does.
There are only a few people who have gotten the Auto trans to straighten out once it starts acting up.
A new transmission is in your future, when is the only real question.
Some people drive on an auto acting up for years and others it goes right out.
My trans blew with no warning at all. It shifted just fine and didn't slip at all.
Then one night while going down the highway it just slipped out of gear and never worked again.
I did not want to deal with possibly having another auto blow so I swapped mine out to a 5 speed. It was a lot of work but I feel it will be worth it with reliability in the long run.
Old Mar 24, 2012 | 07:23 PM
  #17
Originally Posted by crispin
It rarely does.
Was it expensive to swap it? Did you take it to a mechanic or do it yourself?
I've always felt like I was born to drive a 5 speed, as lame as that sounds. When I drive I only use 1 hand and rest the other on the gear shifter. It just feels natural that way. I actually wanted to buy a 5 speed originally, but everyone told me not to since I didn't know how to drive one yet...
Old Mar 24, 2012 | 07:51 PM
  #18
crispin's Avatar
I did it myself
I have less than $100 in the swap after everything was over
here is a write up for it
https://www.hondaaccordforum.com/for...rogress-45489/
Old Mar 25, 2012 | 01:41 PM
  #19
So what does transmission slip actually look like? Ive read a bunch of different things on the web...
I read that One sign of a slipping transmission is higher than normal rpms. What does this mean? I usually get 2.5 before a gear shift while driving normally, and if I'm accelerating hard it only goes to about 3-3.5 before shifting. Idk how to explain it really.
The only thing that makes me think it's the transmission is the fact that my car jerks everytime it shifts gears. Couldn't this just be attributed to bad motor mounts?
Neptun3
Mar 11, 2017 09:13 AM
thunder_x
Nov 8, 2007 03:43 PM
biocpu
May 11, 2007 07:06 PM
BostonPuppyDawg
Jun 19, 2006 05:36 PM
sTeVo!
Jan 11, 2006 12:47 PM
