What kind of accord is this?
Old Jan 18, 2008 | 12:30 PM
finch13's Avatar
Default RE: What kind of accord is this?
F22A
This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar.
Specifications
Bore × Stroke: 85.0 × 95.0 mm
Displacement: 2156 cc
Valve Configuration: SOHC, 16 valves
Compression ratio: 8.8:1
Max power:
F22A1: 125 hp (93 kW) @ 5200 rpm
F22A4: 130 hp (97 kW) @ 5200 rpm
F22A6: 140 hp (104 kW) @ 5600 rpm
Max torque:
F22A1: 137 ft·lbf (186 N m) @ 4000 rpm
F22A4: 142 ft·lbf (193 N m) @ 4000 rpm
F22A6: 142 ft·lbf (193 N m) @ 4500 rpm
These were used from 1991 - 1993. You probably have the F22A4 since you're at the end of the 4th generation and you most likely have a rebadged LX.
Old Jan 18, 2008 | 03:37 PM
ORIGINAL: eric123
ok so just to make sure i'm clear the 91 accord has leather and sunroof on the 4 door. whats the engine code for the lx and ex?
According to your first post you've already decoded your VIN to indicate it's an LX.
You saythere's no sunroof, which (in USA)means that it's an LX.
Anybody can swap a trunk lid, and anyone can walk into a dealer's parts department & buy an "EX" emblem.
Old Jan 18, 2008 | 11:33 PM
bigsack's Avatar
ORIGINAL: nafango2
EX had a sunroof and leather seats.
EX does not mean it has leather in 4th gen cars. if i remember right the leather din't apear till the 93 SE? please correct me if im wrong. my 92 is ex 2.2 4 dr 5spd sunroof, spoiler and factory alloys.
Old Jan 19, 2008 | 10:44 AM
eric123's Avatar
Does it matter if it's canadian?
Old Jan 19, 2008 | 03:50 PM
brittanym06's Avatar
Im not sure if the year model makes a difference, but I registered my car at Honda.com and it gives me every last detail down to the interior colors and weight. I found it to be very helpful.
Old Jan 19, 2008 | 09:01 PM
jeepwm69's Avatar
leather only came on the SE in the 4th gen accords.
Old Jan 20, 2008 | 12:15 AM
  #17
Please post the 6th digit from the vin code and I will tell you what it is...also the 10th digit...
Old Jan 20, 2008 | 01:21 AM
  #18
oma93's Avatar
Register it at honda.com and you'll find out all there is to know abou it.
Old Jan 22, 2008 | 02:27 AM
  #19
YeuEmMaiMai's Avatar
what he means is register it here at owner's link
https://www.ahm-ownerlink.com/login.asp?brand=Honda
MountainManBeard
Jun 27, 2010 08:42 AM
j_man_honda
Feb 27, 2009 12:07 AM
junkboy
Oct 16, 2007 01:58 PM
thunder_x
Jun 1, 2006 02:17 AM
