whats my promblem????
Old Jan 18, 2011 | 12:56 AM
whitetailkiller-2008's Avatar
Default whats my promblem????
i have a 92 accord ex it starts good cold but after warmed up it sputters at low rpm while shifting and when i come to a stop it and goes to and idle when i take off it dies also when i just leave it run after its warm when i touch the gas it will die but after a few tries it does start again new fuel pump and filter thought it was that but a no go plugs seem good too
Old Jan 18, 2011 | 02:23 AM
Does the check engine light turn on or the D4 (or S light) start flashing?
I would check for codes. See thread in the DIY section on how to get CEL codes.
Old Jan 18, 2011 | 11:07 AM
no check engine light dont know what s light is ill try the code thing
Old Jan 18, 2011 | 12:09 PM
If idle rpm is sagging below 500 rpm, the engine may not run and acceleration will be difficult. This is usually the result of clogged idle air control valve (IACV) and very dirty throttle plate.
Check DIY for cleaning and checking the IACV. Throttle plate should be cleaned by reaching in w/ a toothbrush or plastic brush and throttle body cleaner to clean both sides of plate.
Another possibility is poor spark plugs, wires, distributor cap, or distributor rotor. Any weak component of this group can cause engine missing under load.
Spark plug wires can be checked by spraying at night w/ water mist and looking for sparks jumping. Any visible sparks indicates new wires are needed. Other parts should be replaced.
volvoman
Apr 9, 2014 01:59 PM
firefighter44
Feb 22, 2013 06:38 PM
adielramirez
Dec 15, 2012 09:41 AM
wkmitz
Nov 17, 2007 01:24 AM
poff1986
May 17, 2006 09:56 PM
