Wheel Stud Removal
Old Feb 3, 2007 | 02:07 PM
rwrobson22
Default Wheel Stud Removal
First time Honda owner and new to the forum. I searched the forums but had no luck finding my issue thought I would give a post a try. I have a 98 Accord 4 Dr V6. WhenI bought the car the one of the front wheel studs had been crossed threaded so I decided to replace it myself thinking I would have no issue. Removed the wheel, rotor, and got the brake assembly out of the way. I thought I would be able to knock the stud out at that point but it appears the angle is too steep and something from behind it gets in the way. Do I have to remove the whole assemble or should I be able to keep hammering and get this sucker out?
Any help would be appreciated!!
Old Feb 3, 2007 | 09:02 PM
hondadude's Avatar
Default RE: Wheel Stud Removal
You can't look behind the hub plate and see the stud hitting the knuckle?
If you have a die grinder with a cut off 4" wheel you could cut the old stud in 2.
On the older accords you could grind a side of the head off ofthe new stud to get the stud to slip in past the knuckle.
But if that won't work you'll need to pull the bearing apart.
adonus348
Nov 30, 2011 11:49 AM
Hondancali
Jul 17, 2010 09:44 PM
Buckeye
Mar 10, 2010 02:42 AM
Mike 68
Dec 19, 2008 10:33 AM
Tomsaccord
Jun 21, 2008 11:50 AM
