When signaling, everything else on the cluster dims
Old Jun 10, 2018 | 08:56 PM
raidmax's Avatar
Default When signaling, everything else on the cluster dims
Just recently, For some reason. when I turn on my signals, left or right. the lights on the cluster like the D4. abs. parking brake indicator has a slight dimming that goes on and off with the signals. any help would be great. its a 96 honda accord.v6
Old Jun 11, 2018 | 07:14 PM
angrysmileyface's Avatar
I have a similar problem on my 95 wagon. I suspect it's a corroded ground terminal.
Old Jun 11, 2018 | 07:39 PM
Does sound like a ground issue. The connection of the ground wires to the body ground could be an issue. Any corrosion on the circuit board could be an issue.
You may want to stop by a parts store and have them test your battery and alternator to see if they are working properly.
Old Jun 15, 2018 | 02:23 PM
raidmax's Avatar
new battery and alternator, you've mention corrosion on the circuit board, which one are you talking about?
Old Jun 15, 2018 | 02:25 PM
raidmax's Avatar
I clean my ground to frame wire, ground to motor wire, and motor to frame wire.. is the a specific ground wire I need to look for?
Old Jun 16, 2018 | 05:24 AM
Yes the grounds in the cabin and on the back of the cluster
Pajamarama
Aug 27, 2012 06:12 PM
RuthlezzFL1P
Jun 5, 2008 11:55 PM
newheadache
Mar 18, 2008 09:31 AM
marbro
May 20, 2006 10:13 PM
dj.fli4rt
Nov 1, 2005 03:31 PM
