When were transmission problems fixed?
Old Nov 10, 2007 | 02:16 PM
testdrivin
Default When were transmission problems fixed?
Hi all,
I'm looking at possibly picking up an 03 accord ex coupe.
In doing some research, I saw that the TL's and some accords have pretty ugly transmission problems from 98 - (2002 -2004).
The reports seem to vary. On the TL's, it seems like the problem still existed in '04, but on accords it was fixed in 03?
Or can I still expect the transmission issue on an 03 accord?
Old Nov 10, 2007 | 03:02 PM
dknight211's Avatar
Default RE: When were transmission problems fixed?
I believe there was a transmission recall for the TL and Accords in 03, so the 03s should have had the original bad-design transmissions swapped out with better ones ...
Old Nov 11, 2007 | 10:13 AM
testdrivin
So basically anything 04 and newer should be safe then right?
Old Nov 11, 2007 | 10:44 AM
RTexasF's Avatar
Super Member
In 7th generation03's and some 04's had problems with the auto 5 speed trannies. They were not swapped out (unless they cratered), there is an oil jet retrofit that supposedly fixes the problem. I think 05 andforward are squared away.
HondaAccordEX94
Nov 23, 2010 12:29 PM
Tony1M
Feb 20, 2009 12:28 AM
kahnvict850
May 14, 2008 05:21 AM
mig25
May 24, 2007 03:50 PM
Draco
Oct 16, 2006 09:25 PM
