Where to coil pack ? 95 accord
i have a 95 honda accord vtec 2.2 4 cylinder i have a serious misfire on all the cylinder i am trying to replace the coil pack to see if that fix the problem anyone know where the coil pack is loacted at or does it not have one ? it not under the distributor ? or does this car dont have a coil pack. is it just the ingition coil that in the distributor ? anyone know ?
It is unusual to miss w/o load and not miss under load. Perhaps a large intake air leak, check PCV, brake booster vacuum line, and other vacuum lines for leaks.
Are plugs new or recent?
All the plugs and wire are good everything else work normal it not a constant misfire if the car running for a min it would probably misfire about 4 time . It is a obd2 you have to pull the ashtray out and it there even autozone said it was not obd2 cause they could not find the connection .
I think I read somewhere that a few 95 Accords were OBD2.
What codes were detected? This may be best clue to problem.
Cracked rotor or cracked distributor cap could lead to random misfire. Unlikely to be coil.
Clogged EGR and or egr ports...the is a "how to" in the Common DIY Treads at the top of this section.
The ignition coil is not in the distributor it is connected to rhe distributor by the coil wire... (QUOTE=TexasHonda;264388]Ignition coil is in the distributor.
Have you checked distributor rotor, distributor cap, spark plug wires, spark plugs? All these are as likely as a bad coil.
good luck[/QUOTE]
good luck[/QUOTE]
"Flinch" - I'll let this one ride....this thread is over a year old, also the vtec (EX) engines come with the coil inside the dist on this gen....the LX and DX have the external coils....the op said they had a vtec hence internal coil.
James Glenn
Dec 30, 2014 09:04 PM
phantomgrey92
Oct 9, 2013 04:45 PM
reklawj
Jun 22, 2013 11:55 PM
Chach769
Mar 24, 2013 01:45 PM
iluvsnapple
Aug 19, 2011 06:51 AM
