Where is the oil screen on a 1991 Accord LX
Old Nov 9, 2010 | 07:37 PM
45below's Avatar
Default Where is the oil screen on a 1991 Accord LX
Hey there,
Simple question - where is the oil screen on a 1991 Honda Accord LX?
Thanks
Old Nov 9, 2010 | 07:47 PM
In the pan.
I'm guessing the oil level is fine on the stick, still. Is there oil in/on the valve train. Starts and runs, no oil flowing,,,,was before. Not good with the 4th gen's, are you sure the belt is on with proper tension.
Old Nov 9, 2010 | 08:27 PM
45below's Avatar
I have another thread concerning the issue itself. Here's the story - I just replaced the cylinder head and timing belt. It starts and runs, but the oil pressure light is on. I have 5 quarts of oil in there. I only idled it for a couple minutes... didn't want to seize up the head for lack of oil pressure.
I was going to check the oil pressure sensor, so I took off the oil filter, but there was no oil inside, which led me to believe it could be the oil screen. (hopefully not the oil pump)
Thanks for the answer. Which belt are you talking about? As far as I know, both timing belts and both outside belts are on correctly.
Old Nov 10, 2010 | 06:21 PM
The oil pickup is #14 in this picture.
If you remove the oil pan you might find it disconnected or leaking at the gasket #15. If so, the oil pump is sucking air.
CB7-SE-1991
Jan 29, 2013 04:45 PM
Bartman
Oct 10, 2007 09:39 AM
tonyh210367
May 6, 2007 08:45 PM
Samsmommee
Dec 23, 2006 09:13 PM
stunnerx
Nov 14, 2006 09:12 PM
