While stopped, car rocks forward
Old Jun 4, 2014 | 07:22 AM
TexomaAccord's Avatar
Default While stopped, car rocks forward
1997 Honda Accord V6 Sedan Automatic
A/C is off
I'm in D4
I'm stopped at a red light
Foot on brake
Car feels like its wanting to rock forward, move forward, go
No increase in RPMs
If I switch to neutral, it stops
Its like... I stop.... rock forward.... (pause about 10 seconds) rock forward, repeat
Old Jun 4, 2014 | 08:32 AM
shipo's Avatar
A/C is off
I'm in D4
Foot on brake
No increase in RPMs
Is your windshield defroster engaged?
Old Jun 4, 2014 | 08:53 AM
Hmmm... Don't think so?
I'll have to check and see
Old Jun 4, 2014 | 09:02 AM
Excess idle rpm might cause this symptom. What is idle rpm; N and D w/ foot on brake?
An intake air leak can cause an increase in idle rpm.
It is normal to have some tendency to move at idle in D, but not surge or pull forward against brake.
Old Jun 4, 2014 | 09:13 AM
Not really sure what the idle rpm is.. The tach is wonky -- sometimes it works, sometimes it doesn't. Haven't changed the ignition coil yet.
Old Jun 4, 2014 | 02:13 PM
I think what Shipo is getting at...
When you select defroster, it switches on your AC. Then the AC clutch cycles on & off and perhaps this behavior is happening together with the AC clutch cycling.
Old Jun 4, 2014 | 02:55 PM
Would that do it even if the defroster fan was off? I may have the button pushed, but fan is turned all the way off
Old Jun 4, 2014 | 05:49 PM
p0740 ---
Old Jun 4, 2014 | 06:35 PM
Well, if you can figure out whether your AC is actually running or not, that's the important point. And whether that rocking behavior is related to it.
Old Jun 4, 2014 | 06:47 PM
Ok, looked at it and none of the a/c heater defrost buttons were pushed in. Fan hasn't been turned on
98accordlx
Jun 25, 2008 07:37 AM
naruto267
Jun 16, 2008 09:29 AM
tsvore
Nov 21, 2007 03:25 AM
HuYnHness
Sep 7, 2007 09:50 PM
Busareds
Dec 23, 2005 06:52 PM
