Whistling noise from engine
Old Dec 28, 2007 | 06:34 PM
xlibe
Default RE: Whistling noise from engine
sir_nasty...thanks for the warning. I'll try to be careful when I do this.
Old Dec 28, 2007 | 07:34 PM
You should pick up a can of belt dressing from Autozone, walmart, etc and spray it on one belt at a time. If the sound goes away, then the belt is a likely culprit. Tightening that belt might eliminate the noise.
Old Dec 29, 2007 | 12:53 PM
HondatechAV6's Avatar
timing belt was done but what about the water pump, tensioner, tensioner pulley and idler pulley?(all located under the timing belt)
if the noise goes away when you shift into the neutral i'd be weary of blaming something on the timing side and move toward the (crappy) transmission side. of course, it's much easier to say what you think the noise is when you are in front of the car listening to it.
however, another very common failure is the alternator. it whines and moans when it goes bad, it sounds like a UFO type sound(think xfiles, hehe). probably bad diodes.
sstormy99
Mar 19, 2013 07:18 PM
bobbydigital
Sep 3, 2012 06:06 PM
cmoorevt
Nov 12, 2009 06:36 AM
elbarto83
Oct 3, 2007 07:01 PM
Wildcat
Feb 6, 2006 04:57 AM
