white exhaust
Old May 22, 2010 | 08:39 PM
kris_loehr's Avatar
If you let it run does it overheat?
Old May 24, 2010 | 03:29 PM
alpine69's Avatar
Ok, checked the vacuum lines and FPR...nothing to report here. All seemed AOK. Any more ideas?
Old May 24, 2010 | 04:55 PM
deserthonda's Avatar
what color is the smoke ???? if white it is most likely coolant being burnt ( head, head gasket issues
if gray,, oil,,( valve seals, piston rings )
if black ( car running too rich )
Old May 24, 2010 | 06:43 PM
kris_loehr's Avatar
The OP mentions gray a few post up. I wonder about valves seals after overheating.
Old May 26, 2010 | 10:02 AM
alpine69's Avatar
ok, would valve seals be damaged because of previous overheating. Do all my signs point to this being a possibility: heavy gray smoke, good compression, uncontaminated oil/coolant. How is the best way to diagnose valve seals(within my ability). Can this be done visually?
Old May 26, 2010 | 10:30 AM
yes they can,, ,, seals are made of rubber in an overheating situation they get hard thus won't seal properly,,
i have also seen piston oil rings go bad after an overheating situation ,, they get hot and get what we call,,, baked , ( collapsed )
if it is burning oil, i would replace valve seals first,, easier and cheaper ,,,,,,,,,,if it still burns oil,, next step would be piston rings
Old May 27, 2010 | 06:34 AM
  #17
alpine69's Avatar
When I initially had the head off to change the gasket, I noticed heavy gunk built up on the valves, exhaust #2 and #3. I thought little of it because of my lack of experience and just cleaned them best I could. When the vehicle is running, there is smoke not only from the tailpipe but also from the exhaust manifold area. I wonder if it could be that oil is spraying into the manifold from this area? Is that how it would work if the valve seals were shot? Can I inspect the valve seals with just the valve cover off?
Old May 27, 2010 | 08:12 AM
  #18
alpine69's Avatar
Another thought...aren't valve seals usually the cause of smoke only at startup? This car smokes heavy and steady regardless of runtime or rpm.
Old May 27, 2010 | 11:33 AM
  #19
Smoke around the exhaust manifold should be a different problem from tailpipe smoke. Inside the combustion chamber vs. outside the engine.
Old Jun 2, 2010 | 08:04 PM
  #20
alpine69's Avatar
I doublechecked the compression...from right(#1) to left; 195, 210, 210, 200 psi. Can I safely rule out the lower engine(rings, cracked block, etc). What should I do next?
