White smoke from exhaust
Old Sep 17, 2020 | 08:24 AM
Man Eleojo Usman's Avatar
Default White smoke from exhaust
My 2006 honda accord 4cyd is giving out cloud white smoke from exhaust with something smells.when runing the car ..giving me concern plz, i need help.
Old Sep 17, 2020 | 02:49 PM
Seanjordan20's Avatar
Are you the original owner? How many miles? What your oil change interval? How thick of smoke cloud is it? A little is normal at idle anything more is an issue.
Old Sep 17, 2020 | 04:14 PM
yes, i am the ower and the miles is 156000. I change the oil last july .i move within the the city lagos. The smoke cloud thick at high acceleration mostly on reverse.
Old Sep 17, 2020 | 04:43 PM
My questions was how often do you change your oil regularly. I can tell you this, changing the oil at a year interval is not good. Even if you don't hit the mileage you need to change it at least every 6 months. What you're describing is not good. what type of oil do you put in? Did it just start doing it. My 07 does it every once in a while mainly after I don't drive it for a while but only last a couple seconds after start up and it is a real light white smoke that you can barely see. It has 198k
Old Sep 17, 2020 | 04:49 PM
I change my oil after 2 to 3 months .
i used mobil oil 20w50 but started using mobil 5w30 recently .
Old Sep 17, 2020 | 04:55 PM
When you said last July did you mean July 2019 or 2020. I have never heard of using 20w50 in an accord. Did it start smoking after you changed to 5w30 or before.
Old Sep 17, 2020 | 04:57 PM
i do change the oil every 2 to 3 months interval. Using mobil 20w50 but recently start using mobil 5w30..
the smoke started light but now getting much thick.
and smell atimes.
Old Sep 17, 2020 | 05:03 PM
i mean july 2020, initially when i bought the 5years ago i do use rymax 5w20 oil .but since year i started experince little shortage of oil ..i change to mobil ..the smoke start when i start using mobil 5w30..
Old Sep 17, 2020 | 05:19 PM
I too have had a oil light due to shortage a couple of times in the last few years and my oil change interval is every 7500 miles. All I do is add 4 3/4 qts with and additive every other change and haven't had the issue come back up.
I would stick to 5w20 and add liqui moly oil saver every other change (equals out to once a year) and you should be good. I have been using that additive in all my cars for years and never had an issue. I started using it because of a BMW I had with an N63 engine which was notorious for oil consumption. I never had the issue but a lot of others did. I figured me adding that additive from when the car was new saved me from the headaches everyone else had.
Old Sep 17, 2020 | 06:48 PM
nomad2020's Avatar
has the car overheated in the near past?? white smoke could be an indication of a blown head gasket ,, have you checked coolant for possible coolant leak? About the smell,
can you see any leaks at all in engine compartment ?? oil, coolant, etc etc
