White smoke from exhaust
yes, i am the ower and the miles is 156000. I change the oil last july .i move within the the city lagos. The smoke cloud thick at high acceleration mostly on reverse.
I change my oil after 2 to 3 months .
i used mobil oil 20w50 but started using mobil 5w30 recently .
My questions was how often do you change your oil regularly. I can tell you this, changing the oil at a year interval is not good. Even if you don't hit the mileage you need to change it at least every 6 months. What you're describing is not good. what type of oil do you put in? Did it just start doing it. My 07 does it every once in a while mainly after I don't drive it for a while but only last a couple seconds after start up and it is a real light white smoke that you can barely see. It has 198k
the smoke started light but now getting much thick.
and smell atimes.
i mean july 2020, initially when i bought the 5years ago i do use rymax 5w20 oil .but since year i started experince little shortage of oil ..i change to mobil ..the smoke start when i start using mobil 5w30..
I would stick to 5w20 and add liqui moly oil saver every other change (equals out to once a year) and you should be good. I have been using that additive in all my cars for years and never had an issue. I started using it because of a BMW I had with an N63 engine which was notorious for oil consumption. I never had the issue but a lot of others did. I figured me adding that additive from when the car was new saved me from the headaches everyone else had.
has the car overheated in the near past?? white smoke could be an indication of a blown head gasket ,, have you checked coolant for possible coolant leak? About the smell,
can you see any leaks at all in engine compartment ?? oil, coolant, etc etc
