Why would the tranny shift hard after a radiator replacement?
Old Jun 16, 2015 | 04:09 PM
mclasser's Avatar
Default Why would the tranny shift hard after a radiator replacement?
We replaced the leaking rad in my buddy's 01 4-cyl recently and the tranny has been shifting hard ever since. By hard, I mean the car noticeably jerks when shifting in all gears. It sometimes shifts fine, which is weird. The hard shifting is more apparent when it's hotter out and after extended highway driving.
All the tranny cooler and rad hoses are nice and tight with no leaks. Clamps are fine. ATF is at the proper level and drain/filled with DW-1 last year. The tranny shifted perfectly fine before the rad replacement.
Old Jun 17, 2015 | 09:22 AM
Did you correctly re-connect the trans cooler lines; inlet and return?
Have you checked ATF level? You probably lost some ATF when trans cooler lines were removed.
Is Check Engine Light On? If yes, get codes.
live2rice
Oct 23, 2011 12:57 AM
myoldhonda
Sep 13, 2010 12:47 PM
rambleongirl
Aug 10, 2009 04:21 PM
newwct
Sep 19, 2006 10:37 PM
