Wiring diagram available for tracing horn wire?
My 2002 Honda Accord's horn is not working. The relay clicks like it should, but the horns do not respond at all. I am wondering if perhaps the wire has been cut somewhere between.Before I start yanking wires out (I have already pulled the wires from the horns to the battery) any further, is there an online guide showing where exactly the horn wires run, and eventually enter the relay box? I know, I know... it should be fairly obvious... but any guidance would be helpful.
Thanks!
I got a volt checker... had full power to both sides. Turns out.. (dum de de dum)... since the bolt holding the horn onto the frame is the ground, both had to have a very good ground. One of had a bad ground and was therefore not allowing a full circuit. I reconnected both horns (one was loose) and it works fine.
Much ado about nothing.
Thanks!
Thanks!
maggie
Sep 29, 2010 07:27 PM
