Wiring my Accord
Old Mar 26, 2021 | 05:49 AM
Lokisukaido's Avatar
Default Wiring my Accord
Hello all,
I have been searching for an answer to this question but to no avail. I saw a post from a few years back that almost answered it. But, I didn't think I should necro that thread. So, I am asking here. I have a 1997 Accord LX Coupe with a 4 cyl non-VTEC engine. When I got it, there were some repairs that are needed. Specifically, it looks like she needs a new Left side wiring harness. I have looked online, and it appears the part number I need is Honda Part No.:32120-SV4-A11. I was able to find a part online that looks like it'll work. But, the part number is 32140-SV2-G03. I cannot tell if this would work. Someone in another forum speculated that this might be for the V6 model. But, then, can I still use it? Any search done on using a V6 wiring harness on a V4 engine comes back with results for either swapping the engine or V6 to V8 issues. I just want to get her to daily driver status. Any help is greatly appreciated.
Old Mar 26, 2021 | 08:35 AM
kevtech's Avatar
Old Mar 26, 2021 | 11:06 PM
From kevtech's post, it is for the EX. The EX has the vtec and also some differences in how the distributor is wired. Some of the connectors may be different.
I'd probably go to a u-pull-it yard and get a harness from a 96 or 97 non-vtec accord that looks in good shape. I don't typically see a lot of bad wire harness posts on this forum, so a used harness is not a bad option. The fit will be identical and you should find a lot of potential donor vehicles. Ebay is another option.
Old Mar 26, 2021 | 11:13 PM
I already answered him on H-T. The left engine compartment harness is the same for 97-97 LX and EX 4 cylinders.
Originally Posted by tech8
For your 1997 LX with MT, the U.S. Honda part numbers are 32120-SV4-A11 or 32120-SV4-305 (superseded A11). The part number 32140-SV2-G03 doesn't show up on U.S. Honda dealer sites; so, it may be related to exported models in other countries where the connectors may or may not be the same (for example, they may have some other running light configuration or connectors).
If you search at a junkyard/salvage yard you're essentially looking for the left engine harness from a 96-97 LX or EX (MT and AT are the same). 94-95 left engine harness are not the same (less connectors).
Wagon, DX, and V6 are different left engine harness. V6 has different and less connectors for that left engine harness.
Ryan1
Feb 1, 2021 10:34 AM
bholloway
Nov 27, 2019 05:08 PM
Rob heath
Jan 29, 2013 07:06 PM
ryder_kid
Oct 12, 2011 09:02 AM
Ron
Feb 9, 2011 08:02 AM
