wonky accord door locks
Old May 5, 2011 | 07:35 PM
twasau's Avatar
Default wonky accord door locks
Hi, My locks keep locking and unlocking as we drive. Any ideas how to fix this? Thanks
Old May 5, 2011 | 08:09 PM
Well if we knew the year model and that it really would help in answering/helping you.....I bet we know the answer but, Help us help you.
Old May 6, 2011 | 10:13 AM
twasau's Avatar
Default wonky door locks
Sorry about that...accord 1990. Thanks!
Old May 6, 2011 | 12:23 PM
Locks are triggered by the door lock switch and interior door lock switches. One of these is probably worn/loose causing intermittent contact.
It may be painful to find which is causing the problem. Most likely are driver's door lock switch or driver's door lock key switch. You might try cycling the door lcok key switch and spraying some WD40 into the key entry point. WD40 can work wonders on switches,...if you can get it to the switch.
Otherwise, you'll need to remove door panel to access key switch.
Old May 6, 2011 | 01:12 PM
The door lock actuator can also cause the door lock to cycle.
Here is a post from another forum on how you can repair the actuator. This is for the 94-97, but should be similar to your car. Just copy this link and paste into your browser.
honda-tech.com/showthread.php?t=2465699
Old May 7, 2011 | 09:22 AM
twasau's Avatar
I am very grateful for your time and responses. Thanks so much, God Bless,
I'll let you know how it goes. Don't forget your moms tomorrow, Mama Twasau.
trolddk
Jul 3, 2013 06:08 PM
Xavior
May 15, 2010 05:13 PM
abhanu
Mar 31, 2008 11:02 AM
03 Coupe
Feb 22, 2007 06:32 PM
hurkes
Jun 23, 2006 01:51 PM
