Xenon Bulbs
Old Apr 9, 2006 | 10:48 PM
eckhart's Avatar
Default Xenon Bulbs
I purchased some Xenon bulbs to replace my stock ones in the 92 Accord. I was unaware that it was so difficult to replace them. Apparently the battery has to come out among other parts. The bulbs I got were 9005 and 9006. I believe the 9006 are the low beam and 9005 are the high - please correct me if I'm wrong.
Would anyone have any visual instructions are to what to remove and how to remove it to access what I need to access? Any sage advice?
Thanks!
Old Apr 9, 2006 | 11:34 PM
03AccordEX's Avatar
Default RE: Xenon Bulbs
As far as I know (and lightshow or the other guys will correct me if Im wrong, its been awhile since I've had my 91), All you have to do is move the plastic/rubberish fenderlining on each side to get to the bulbs, no need to take the battery out at all.
Old Apr 10, 2006 | 04:53 AM
lightshow's Avatar
there is one plastic screw type thingy just turn it counterclockwise a little and the bulb comes right out. the 06's are for the lows. if you are having troubles then you have the bulbs put in professionally.
Old Apr 10, 2006 | 03:59 PM
sir_nasty's Avatar
here's a removal diagram for a 91... Also, keep in mind DO NOT TOUCH the bulb itself on halogen bulbs... The oils on your hands will kill the bulbs/shorten their lifespan signifigantly... or so I've always been told... Anyway, here's the pics. If you're still having issues post some pictures of what you're looking at...
[IMG]local://upfiles/3079/5646632C9AD644A6A67870C0F9AFF0DB.jpg[/IMG]
Old Apr 10, 2006 | 04:41 PM
lightshow's Avatar
i thought that was how the civic bulbs (h3) went in. ill try to take a look at my 06's here when i get out of class.
Old Apr 10, 2006 | 04:46 PM
sir_nasty's Avatar
that's the manual page from a 91 accord... I know that civic's have a retainer spring and all that other junk very similar to that page I posted... guess I've never actually looked at my accord..
Old Apr 10, 2006 | 05:43 PM
lightshow's Avatar
ok then im probably wrong, because its been a while for me too.
Old Apr 10, 2006 | 06:18 PM
You were told correctly on the oil on your hans also moisture out side if it's raining will also make them go out faster...
ORIGINAL: sir_nasty
HuYnHness
May 4, 2012 08:00 AM
jbrams
May 11, 2010 10:30 AM
Dong
Mar 30, 2007 10:38 PM
mngantung
Aug 8, 2006 07:07 PM
azmmza
Apr 20, 2006 05:41 AM
