HAF Help & Suggestion Center Need help with HAF? Ask. Have a suggestion to better HAF? Tell us here.
Cooling Fan Stops with A/C On Intermittently
Old Sep 18, 2024 | 03:19 PM
martyk's Avatar
Default Cooling Fan Stops with A/C On Intermittently
My 2011 EXL V6 Coupe recently has an intermittent problem with the cooling fan dropping out when the A/C has been on for a while. The fans operate normally without A/C being turned on. The fan dropout causes the coolant temp to go up and the A/C stops cooling, but, the A/C fan is still blowing hot air. I know the wiring for the fans is complex and I don't have the wiring diagram. Any idea what is causing the problem??
97hondaguy
Jun 9, 2024 01:58 AM
TimiAkhigbe
May 1, 2023 03:38 PM
duanel40
Apr 29, 2023 02:38 PM
rl4518
Apr 8, 2022 10:38 PM
denerodoc
Sep 21, 2017 03:01 PM
