98 Catback Exhaust
Old Jan 14, 2013 | 11:48 PM
phantom699's Avatar
Default 98 Catback Exhaust
hey guys, I have a 1998 honda accord ex 2.3l ulev 4dr sedan.
I recently bought a varex muffler, which is a 2.5' inlet and 4' outlet, which is 15' in length. However, I am trying to find a catback exhaust to match. Plan on removing the mid muffler and just having a resonator and piping.
Is there a system out there which is 2.25' to match the stock? which i can weld the muffler onto the back so it wont stick out and w/o any drone? or should i attempt to keep what i have now and just weld it on.
I plan on keeping the sound stock and i dont want the can to stick out the back of the car * aka stock* but i would like decent flow and a good sound when the butteryfly valve is opened wide open.
* i also have a 2.25' aem short ram intake, reason i want to match a 2.25' catback*
* also have a 3' cold air intake which comes in 2 tubes incase i need to make it a short ram.
** money is not a problem either. I would prefer a brand name like megan racing or greeddy etc.. but also want something that would be a semi direct fit and not look like a ricer.
*** last note - my accord is a sleeper. f23a with 4-2-1 headers, sri, jdm dyno tuned, msd ig, upgraded flywheel etc, plan on redoing entire body in carbon fiber over the summer so a nice shine on the exhaust would be perfect
thanks for any feedback
Old Jan 16, 2013 | 07:29 AM
Random Cheese's Avatar
When you put on the 4-2-1 header, did you have any problems with the o2 sensor? I've been considering an 4-2-1 but I'm worried that the ULEV engine controller might not like having the sensor input from only one cylinder.
Old Jan 21, 2013 | 08:40 PM
phantom699's Avatar
I went to Import Tuning in Philly after having them installed, and i did have a check engine light go on as soon as i started but went away after 5 minutes, so im not sure. I do know that the ULEV does not like a 4-2-1 or a 4 to 1 header.. as it removes one of the o2 sensors, but as long as its reading correctly you might luck out
Old Jan 23, 2013 | 09:26 PM
phantom699's Avatar
u can also just reprogram ur ecu to not measure using the o2 sensor before the cat, there for no harm no foul
Old Jan 24, 2013 | 12:12 AM
phantom699's Avatar
Kk so i finally got the varex installed. Just took a straight pipe, went 2.5' so i could bolt the muff w/o welding since its stainless steel. Quiet when closed, and deep loud purrs when open no rice at all. I put no resonator on and trashed the mid muffler also, nothing but pipe. Only downside thought... lost some clearance from bending the pipe and it looks like its a foot off the ground hehe. Pulled over for the noise also. Sleeper be done!
frankiexthedork
Apr 11, 2008 08:36 AM
amybee
17
Oct 24, 2007 12:25 AM
prttysic
18
Sep 5, 2007 09:59 PM
Windigo
Jun 21, 2007 10:30 PM
HondaLawgik
Feb 26, 2006 11:05 PM
