99 Honda Accord EX Coupe v6 Exhaust Mufflers
Hi I'm new to the forum and I just needed some help picking out a muffler. I have a 1999 Honda Accord EX coupe v6 3.0L pretty much bone stock and I was wondering what is the inlet measurement for stock exhaust piping? They have the regualr universal muffler which is 2.4" inlet ID and a turbo version which is 3" inlet ID. I'm not sure which will fit my car. Here are some links for reference:
M-N1 Muffler Megan Racing M-N1 Turbo Muffler http://www.meganracing.com/product_d...d=389&catid=21 |
most of the hondas are 2.25' piping. A lot of "performance" parts start at 2.5' +, and 3' are normally for turboed engines. If you are going bigger then stock, i would suggest not going more then .25' under/over what stock is. There are adaptors for the cat back so that a 2.5' will fit a 2.25' outlet, and you can always weld it on if it doesnt direct fit bolt on. Also, N1 imo are not that good, there loud and will get u pulled over because they almost always amplified.
* i am running a varex 2.5' inlet oval muffler, they are illegal because it has a butteryfly valve to adjust the volume, but as long as u have a resonator inbetween the cat/muff and keep it under 95db you should be good. i think most laws state that 92-95db at 3500rpms WOT |
Originally Posted by phantom699
(Post 308781)
(Post 308781)
* i am running a varex 2.5' inlet oval muffler, they are illegal because it has a butteryfly valve to adjust the volume, but as long as u have a resonator inbetween the cat/muff and keep it under 95db you should be good. i think most laws state that 92-95db at 3500rpms WOT MagnaFlow Exhaust Products - For Trucks, Suv's, American Muscle, Diesel, & Sport Compact Vehicles |
(Post 308781)
dont be ashamed to use ebay and look for mufflers, there not made as good but if your staying stock dimensions with a dual tip then you can just get a bolt on for CHEAP.
also if your having a shop weld/bolt it on for you, make sure they have j hooks incase the original bracket does not work |
I recommend Ebay. I just picked this up for $ 157.00. I plan on installing it this weekend so I can't tell you how it sounds yet. The model I picked up is sold out but there are some similar set ups for about the same price as long as you don't live in Cali. you should be fine.
(Post 311246)
Originally Posted by Aiken_Roo
(Post 311297)
(Post 311297)
