CB7 Exhaust Question
Old Sep 26, 2010 | 10:05 PM
DomkeBoy's Avatar
Default CB7 Exhaust Question
I have custom pie cut piping. It has a nice tapered down set up with clamp right where the resinator starts. From there it's 2.5" all the through including the muffler. The catch is. This is on my '95 accord. Are the bends and lengths the same on the CB7's? I am getting one this week and wanna swap the exhaust. Also, would having that big of piping mess with my gas milage and would it sound ridiculous once its on the 4-cylinder? I would measure it myself if I could, but can't yet, so I figured I would ask the people here that may already know.
Thanks guys.
Old Sep 26, 2010 | 10:13 PM
g22cd5's Avatar
Supper Moderator
yes you can use it. I have a 94 ex pipe on my cb7. But it will need to be modified a bit. but the pipe is pretty much the same bends..you will have to shorten up around the axle back area. you will see what I mean when you start to the swap
Old Sep 26, 2010 | 11:46 PM
DomkeBoy's Avatar
Nice! Do you mean like shorten it so it doesn't stick way out the rear? Mine is perfectly tucked on my '95. Are the hanger rubbers the same?
Old Sep 27, 2010 | 06:17 AM
g22cd5's Avatar
Supper Moderator
no I mean you have to shorten it to make the last bend fit right. an yes all the hangers are the same as far as I remember
Old Sep 27, 2010 | 10:44 AM
DomkeBoy's Avatar
Oh I get what you're saying. The straight part before the bend around the axel. Cool, a measuring tape, couple cuts, and some more welds should do it. Thanks.
Old Sep 27, 2010 | 02:58 PM
g22cd5's Avatar
Supper Moderator
what I did was cut the both flanges off the axle back and shorten the pipe their and weld back and it was good to go. I was also useing a EX witch it the vtec pipe b/c is was slightly bigger than my stock cb7's f22a1 pipe
CBbattlesedan
Jun 25, 2013 08:13 AM
DomkeBoy
Sep 28, 2010 09:50 PM
clutch811
Aug 3, 2010 04:48 PM
thunder_x
Sep 10, 2007 08:56 PM
yosfynest11190
Mar 20, 2007 03:19 AM
