Cracked exhaust manifold: options?
Old May 26, 2012 | 02:37 PM
Pajamarama's Avatar
Exclamation Cracked exhaust manifold: options?
Hello!
I have a hairline but significant crack in my F22B1's exhaust manifold. Pics attached. I would appreciate thoughts and comments on what I have determined are my options for dealing with this.
a) Do nothing
I am guessing leaving it this way will cause performance/MPG degradation and could damage the engine.
b) Take to mechanic or dealer to fix
Drawback: $$$ Advantage: fixed well and more or less permanently
c) Fix myself using manifold pulled from a junkyard
Advantage: Save $$$ Disadvantage: used part could have unforseen flaws
d) Fix myself using new OEM part ordered online
Advantage: new OEM part Disadvantage: $$
e) Fix myself using non-OEM manifold ordered online
Here is a link to the replacement manifold I am considering ordering:
1997 Honda Accord Honda 2.2L Exhaust Manifold with Heat Shield at 1AAuto.com with how-to installation video.
Advantage: new part, save $ Disadvantage: non-OEM part
f) Patch crack using high-temperature metal repair compound
Saw stuff at my car parts store that supposedly was good up to 2000 deg F
It wasn't this brand, but similar stuff:
http://www.permatex.com/products/aut...r_Compound.htm
I am leaning to trying f) first and if that doesn't work trying e).
Thoughts, comments and suggestions? I watched a YouTube video and changing the manifold seems somewhat straightforward. Looks like the biggest concern is making sure the gaskets get installed correctly.
Thanks!
Attached Thumbnails Cracked exhaust manifold: options?-01.jpg   Cracked exhaust manifold: options?-02.jpg
Old May 26, 2012 | 03:21 PM
crispin's Avatar
C is the best answer.
Old May 26, 2012 | 03:24 PM
crispin's Avatar
While 'e' seems like a good idea cause it is a new part and the price is high
cheap and cast iron are not good words together.
I would have concerns with it cracking from heat.
Used from the junk yard should be less than $25 (around $10 where I live) and is an OEM part.
The OEM's do not normally crack so the odds of getting another bad one is pretty low.
Old May 26, 2012 | 03:25 PM
crispin's Avatar
I just looked at your pictures, that is a pretty bad crack and you should fix it ASAP.
Old May 26, 2012 | 03:55 PM
Pajamarama's Avatar
Understood. Since there's no guarantee I can immediately find a matching part at my local pick-a-part tomorrow, what do you suggest as a backup plan?
Do you think the high-temp compound is worth trying at all, even as a temp fix?
Old May 26, 2012 | 04:23 PM
crispin's Avatar
I think the odds are pretty good you can find another manifold at the pick-n-pull
Mine has 6 5th gens and 8 4th gens right not.
I guess if you cannot find one then the high-temp is something to do. I have no experence with it but I guess it would be like JB weld - which I have used many times with sometimes good sometimes not so good results.
Old May 27, 2012 | 08:12 AM
I agree with Crispin -"C".....if that doesn't work then "E".
Also be sure to inspect the mounts, excess engine movement can/will cause things like this.
Old May 27, 2012 | 08:18 AM
crispin's Avatar
Didn't even think about that.
Check the front motor mount between the motor and radiator.
That one seems to fail pretty commonly on our generation
Old May 29, 2012 | 10:19 AM
Pajamarama's Avatar
Well I went to the Pull-A-Part this weekend in search of a replacement exhaust manifold. Unfortunately, since I have an EX I needed to find a car with a F22B1 engine and there were only 2 -- both with engines completely gone. Most of the 94-97 Accords at the yard were 6 cylinders or non-VTEC 4s.
I might try to hit a second Pull-A-Part in my metro area. Unless there's a different Honda engine with a fully compatible exhaust manifold, I don't hold out a lot of hope of finding my part there.
Backup plan is to order this and install it myself:
More Information for DORMAN 674509
I will take my old cracked manifold to a muffler shop to see if someone can weld the crack shut, giving me a backup manifold to have as a spare.
And yes I will have someone check the motor mounts. Good idea.
Old May 29, 2012 | 10:25 AM
Have you searched car-part.com? You can search for manifolds in your area, and being in a large city like you are I wouldn't think it would be hard to find one.
