Double CAI
Old Dec 2, 2008 | 01:43 AM
AccordLXMaster's Avatar
Default Double CAI
im thinkin about puttin 2 cold air intakes under tha hood...they arent to high pricey but they arent very cheap hey..beggars cant be choosers right??...heres what they look like
http://www.car-stuff.com/carparts/ho...tv3222121.html
how hard would it be to setup 2 of these??...i have an accord lx 98' 2.3L I4 auto
heres an exact counterpart of my car under the hood
http://www.youtube.com/watch?v=OKLaRqXgs5E
Old Dec 2, 2008 | 04:15 AM
Antarctica's Avatar
Default RE: Double CAI
Why 2? And go with AEM.
[hr]First of all, you have no need for a dual intake because your car does not require tons of air, but if you want one, then you go right ahead with your welding machine and custom mod your throttle body to accept 2 intakes. Second of all, my personal opinion is to go with AEM. They're a common name brand and are known for their performance increases. For a cold air intake, all you really need is a good filter, perhaps a K&N or AEM one will do. As for installation, removing yoru old intake and putting the new one on should take no more than 15 minutes. Just remember, quality, not quantity.
Old Dec 2, 2008 | 07:29 AM
Tippman7641's Avatar
i dont even need 2 on my v6, one will sound better
Old Dec 2, 2008 | 08:10 AM
2? that doesnt even make sense. Unless you have a G35 or 350z with dual throttle bodies.
Old Dec 2, 2008 | 09:02 AM
finch13's Avatar
Dont forget to top of your blinker fluid and inspect the power bands while youre at it!
Old Dec 2, 2008 | 09:25 AM
cjdm98's Avatar
All jokes aside LXmaster,try to do a bit of research before this bizzare topic pops up again,In order to have two intakes period,a vehicle must have to TBs. The closest thing to that will be to get Individual TBs which i believe are not even made for the 6th gen.
Old Dec 2, 2008 | 09:27 AM
ORIGINAL: cjdm98
All jokes aside LXmaster,try to do a bit of research before this bizzare topic pops up again,In order to have two intakes period,a vehicle must have to TBs. The closest thing to that will be to get Individual TBs which i beleive are not even made for your car.
I have seen F22's with ITBs, and could point him in the direction as to where to get them, but even then you dont put a intake on each one, most just run open stacks, but some put a sealed box on and run one intake tube(thanks to the intake being on the back)
falkore24's Avatar
Where the air combines, whether you build 2 TB's or Y the pipes first, there will be a pressure drop. I'd expect that to be greater than the increased pressure drop of a single pipe, so 2 CAI's will result in less power than 1. They should be a little quieter, but not too much.
Old Dec 2, 2008 | 10:20 AM
klrspz's Avatar
hahah... thanks for making my day a little bit brighter...
Old Dec 2, 2008 | 11:47 PM
Leosaccord's Avatar
WTF 2
