exhaust cutout: gain or loss?
Old Sep 10, 2009 | 02:46 PM
shabba's Avatar
Arrow exhaust cutout: gain or loss?
can sumbody tell me if im gaining or losing power when the cutout open
Old Sep 10, 2009 | 03:07 PM
accord_raffi's Avatar
There is no need for an exhaust cutout on n/a cars like this because you aren't producing enough exhaust pressure where it has to be evacuated quickly.
Old Sep 10, 2009 | 10:30 PM
shabba's Avatar
idk man it duz feel slightly faster i mostly hav it cuz it sounds crazy haha
Old Sep 17, 2009 | 12:17 AM
It feels faster in the the upper rpms because you have no restriction/maximum flow capacity. But in the lower rpms the flow velocity is low because of the lack of piping.
Your exhaust is similar to a garden hose. When the water runs through, it pours out at a slow velocity because the hosing diameter is big. But, when you put a finger of the hole, you notice the velocity of the water coming out has increased. With exhaust, big piping (or in your case, lack there of) creates power in the top end, but when your in the low rpm's the velocity is slow because of the lack of piping.
So yes, you're making power, but only in the top end.
Old Mar 11, 2010 | 11:38 AM
g22cd5's Avatar
Supper Moderator
Default I didnt want to make a new thread for my question.
Is there a way to tune a electric exhaust cut out to open ONLY when vtec engages?? Like run off the ecu somehow so it can have a nice back press. for low end and when she needs to scream the cut out opens. Iv seen the ones where you can flip a switch and it opens but I haven’t seen one that automatically opens at a set rpm or something. Is there a way?
*edit*
I’m more asking this question for tunable ecu (chipped/standalone) (for a h22) not running a ecu on stock air fuel ratio.
Old Mar 11, 2010 | 11:47 AM
19Accord97
You can.
Alot of people will hookup a led or whatnot when VTEC engages. You could use that power as a "signal" for the electric cutout to open.
Old Mar 11, 2010 | 12:19 PM
g22cd5's Avatar
Supper Moderator
Sounds good. I'm thinking about running OE exhaust with a cutout for vtec...still debating tho. Should I use bigger pipe then stock even if I’m using the cutout? I want to run a full OE exhaust muffler and all for a sleeper and for long trips. Bwahhhhhhhhhhh! For more than a 1hr gets on my nerves.
Engine: h22 slightly built.
9DEX
Dec 22, 2011 10:03 AM
pbplayer257
May 2, 2010 09:41 PM
shabba
Sep 13, 2009 03:19 PM
rachitparikh200
Jun 3, 2009 01:51 PM
roxon
Sep 8, 2008 09:08 AM
