exhaust question
Old Apr 19, 2007 | 08:43 PM
ckebottle's Avatar
Default exhaust question
Is there a big difference from buying a cat back exhaust as opposed to buying a muffler and having a shop do the pipes??
Also how about a straight pap (oops meant pipe) from the cat? Instead of having the bend. Would that be a good idea? Trying to get an idea so any help would be appreciated =)
Old Apr 20, 2007 | 02:13 AM
Shadow1992's Avatar
Default RE: exhaust question
If it's a good shop you use..the only differance would be cost and easy of install. A full cat back might be a bit more expensive, but can be done by yourself in usually an hour. If you have a shop do it the only thing you really need to make sure is that they use mandrel bends in the pipe, not crush bends.
Now a straight pipe would be more effecient than a pipe with bends...only thing you'd have to do is find a way to install it that wouldn't interfere with other components and wouldn't drag on the ground.
deadaccord92
Nov 17, 2010 10:05 PM
calenatar
Feb 6, 2006 01:47 AM
mds1000
Jan 3, 2006 11:48 AM
Accord5726
Nov 5, 2005 03:19 AM
Jan 15, 2005 04:22 PM
