How do you remove the exhaust manifold?
Old May 9, 2006 | 12:51 AM
19Accord97
Default RE: How do you remove the exhaust manifold?
Well I've seen quite a few Accord that have headers w/o their heat shields on. Do you guys think i should put it back on or just leave it off?
Old May 9, 2006 | 12:55 AM
marbro's Avatar
if youre going with a ceramic manifold, you reeeally dont need it, but in general its not needed, but it does help reduce heat, but the stock manifold has mount points on it for the heat shield so you will lose it when you upgrade
Old May 9, 2006 | 12:59 AM
19Accord97
Okay, thanks for your help guys They are stainless steel headers by the way.
Old May 9, 2006 | 09:02 PM
legionofone's Avatar
heatshield also slows header cooling so if ur gunna drag race... then no heatshield is best
Old May 9, 2006 | 11:47 PM
19Accord97
I don't really race, I try to baby my car! lol But every once and awhile I get on it. So do you guys think everything will be ok and the extra heat wont shorten the life.melt anything?!
Old May 10, 2006 | 11:37 PM
LinX's Avatar
You car will be fine. Don't worry about it.
Old May 11, 2006 | 12:42 AM
  #17
19Accord97
Well thanks to everyone for the reassurance and support.
Old May 15, 2006 | 10:22 PM
  #18
19Accord97
Just have one more question! Has anyone had problems with the "check engine" light going on after instaling headers and an exhaust? Also, do I need to reset the ecu? And if so do i need to simply unhook the battery for awhile or remove a fuse? Thanks guys! You rock[8D]
Old May 16, 2006 | 03:52 AM
  #19
tom15425's Avatar
As far as the resetting of the ECU, it is a good idea to do it if you make any modification to your car and you can do it either way you mentioned. I find it easier to disconnect the battery and then let it idle for 10minutes and relearn, but either way works. I can't say from experience that if you installed a cat back AND a header the light wont come on, but with just my exhaust the light has not bothered me. I have a feeling it won't though (for what thats worth) because the actual cat will still be doing it's job regardless of how the gases get there and so the O2 sensor should still be happy.
Old May 17, 2006 | 12:23 AM
  #20
19Accord97
Thanks Tom! I just didn't want the check engine light coming on a creating problems. Thanks for your help and reassurance, I really do appreciate it.
