magnaflow vs. custom
Old Sep 8, 2007 | 10:08 AM
srpowersuw's Avatar
Default magnaflow vs. custom
Quick question for those that have tried Magnaflow's exhausts or had one custom made at a shop. What are the pros and cons of one versus the other? Does it cost more to have a custom one made? Are performance gains any different? Any help would be appreciated.
Old Sep 8, 2007 | 09:59 PM
falkore24's Avatar
Default RE: magnaflow vs. custom
Custom is not dyno tested for gains nor can you listen to sound clips to hear what it sounds like .... also, unless you knowhow to do accoustic calculations for dynamic systems, there's very little chance that your custom exhaust will perform as well as a tested kit.
Old Sep 11, 2007 | 10:07 PM
vtecHef's Avatar
I don't have either but i do know if u get custom and have it straight piped ( w/o resonators) it will sound like trash....I would say def. go for the magnaflow.. im not farmilar with magnaflow but if they have stainless.. it looks alot bettter too!
Old Sep 12, 2007 | 11:36 AM
sUbLiMe96's Avatar
I got a custom 3" with a highflow Magnaflow cat (metalic comb)..sounds MeanMeanMean...but im boosting so....?
[IMG]local://upfiles/10481/BFABAF3B6F9F47F9883A08291BC5614E.jpg[/IMG]
Old Sep 12, 2007 | 01:40 PM
94Honda's Avatar
i have a stock exaust and want something diff. its a 94' should i keep the cat and resonator then with a muff. or bypass the cat and resonator and just muff?
Old Sep 12, 2007 | 01:59 PM
sUbLiMe96's Avatar
My opinion, if your gonna due any kinda exhuast work i would upgrade the piping to maybe 2.5" atleast from the cat_back...if you got the money get a highflow cat and replace the OEM (lots of restriction).
Old Sep 12, 2007 | 02:12 PM
falkore24's Avatar
94: keep the cat. the gains are not enough to justify the polutants ..... acid rain contributors. If you want to go the cheap route, do the 2.5" pipe like sublime said. That is the biggest restriction in your system. If you intend to do the pipe and muffler, you might as well get a cat-back system. The last part would be the cat.
HondaLawgik
Feb 24, 2011 12:14 AM
HondaLawgik
May 3, 2006 02:47 AM
HondaLawgik
Apr 11, 2006 09:43 AM
bullet099
Nov 6, 2005 11:08 PM
dinzer
Oct 6, 2005 11:30 PM
